Mahindra 2638 HST quit.
   / Mahindra 2638 HST quit. #21
I talked with them yesterday and they finally got it into the shop. No status when they will break it down. Will update when I know more. Did you get yours from Anderson Feed in Dahlonaga? I am also in Cleveland GA.
Hhmmm, this may be your tractor! Lol
It is kind of dirty and an old light blue shirt next to the seat. I hope it is mine you are working on. I have been down since March. If it is mine, do you think it was badly put together? Anyhow, send me a message via my email.
BTW: Are you working on it at Anderson or somewhere else? I would like to swing by and look at what you found.
Maybe it broke all the bolts holding the ring gear in place? Or something in the diff let go.
I talked with the tech working on it and it was the bolts for the ring gear. Bummer! I have never had anything like this happen before but, there's a first time for everything.
   / Mahindra 2638 HST quit. #25
Definitely a bummer! Hopefully the bolts just fell on the bottom of the rear end housing and didn't cause any further damage by getting stuck in between gears or something.
   / Mahindra 2638 HST quit. #26
Here's another forum for Mahindra seems nothing
but problems: mahindra problems
Sorry your tractor is down, hope it will get fixed soon.
And you fare better than the ones on the forum.
willy
Well folks, my tractor is fixed and just waiting for them to deliver it. Just three months. Huh.
Got my baby back and found some issues. First, it took forever to get started. Then, it didn't have enough power to back up a hill. A friend was over to the house and looked at it and discovered a fuel leak at the bottom of the fuel filter. If I use the prime button, it will start and run until I turn it off at the end of the job. I talked with the service man who did the work and he thinks something is loose around the fuel filter. Makes sense why it is loosing its prime. Bottom line, I am excited about having my mistress (wife calls her my mistress) back and can now get a few jobs done that have been pending for awhile.
   / Mahindra 2638 HST quit. #29
Which fuel filter? There is one on each side , I just replaced both of mine after getting bad fuel and having to drain everything . The spin on filter was easy , The other one you have to clamp the line from the tank or you will lose a lot of fuel.
It's the one with the prime on top, with electronic device on the bottom.
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
TRAILER CHASSIS (A51247)
TRAILER CHASSIS...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
