Mahindra 2638 Crank No Start
   / Mahindra 2638 Crank No Start #1
Fleury413
Mahindra 2638 HST Cav
I have a mahindra 2638 hst with around 500hrs on it. Tractor sat for 2 weeks. Went to start it and cranks but no start. Fuel filter was leak at the top by the gasket. Replaced that. Loosened injectors and bled air out. Tractor will run on ether and has plenty of fuel getting to the injectors just won’t fire on its own. Has anyone had this issue or has any ideas on the problem. Thank you
   / Mahindra 2638 Crank No Start #2
The way to bleed air is......
Remove the "driver's" side panel .
Get a 10mm wrench & slightly crack open the bleeder screw on the black- painted Bosch filter assembly. The screw is on the back side. Aggressively pump the top of the filter assembly to build pressure and close the bleeder while fuel is squirting out.
The method you described applies to old school tractors without high pressure common rail injection. Doing that here will create more problems.
________________
Assume your fuel is CLEAN
   / Mahindra 2638 Crank No Start #3
Bleeding methods vary by tractor model. Get the owner's manual for your tractor and follow their suggested bleeding steps.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
PALLET BOX OF MISC (A58374)
PALLET BOX OF MISC...
PALLET OF MOWER BLADES & MISC PARTS (A58374)
PALLET OF MOWER...
