Mahindra 2638 Crank No Start
   / Mahindra 2638 Crank No Start #1
Fleury413
Mahindra 2638 HST Cav
I have a mahindra 2638 hst with around 500hrs on it. Tractor sat for 2 weeks. Went to start it and cranks but no start. Fuel filter was leak at the top by the gasket. Replaced that. Loosened injectors and bled air out. Tractor will run on ether and has plenty of fuel getting to the injectors just won’t fire on its own. Has anyone had this issue or has any ideas on the problem. Thank you
   / Mahindra 2638 Crank No Start #2
The way to bleed air is......
Remove the "driver's" side panel .
Get a 10mm wrench & slightly crack open the bleeder screw on the black- painted Bosch filter assembly. The screw is on the back side. Aggressively pump the top of the filter assembly to build pressure and close the bleeder while fuel is squirting out.
The method you described applies to old school tractors without high pressure common rail injection. Doing that here will create more problems.
________________
Assume your fuel is CLEAN
   / Mahindra 2638 Crank No Start #3
Bleeding methods vary by tractor model. Get the owner's manual for your tractor and follow their suggested bleeding steps.
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2012 Ford F-350 Omaha Service Truck (A48081)
2012 Ford F-350...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
ECHO CS-4920 GAS CHAINSAW (IN BOX) (A50460)
ECHO CS-4920 GAS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
ECHO PAS-225 GAS POWERED WEED EATER (A50460)
ECHO PAS-225 GAS...
