Mahindra 2540 Wont go into gear
   / Mahindra 2540 Wont go into gear #11
If you are in neutral it should go both ways,
here is what you are trying to move;
So I should be able to rotate this left and right with the clutch engaged?
   / Mahindra 2540 Wont go into gear #13
With the tractor off and both gearboxes in neutral, should be able to.
So with both shifters in neutral i unpinned the linkage. When the linkage was unpinned I still did not get full travel from coward and reverse but could also not turn the number 11 tab left or right in the diagram above.
   / Mahindra 2540 Wont go into gear #15
Assuming you were able to get some leverage on #11?
I mean it’s definitely not going by hand…. May be able to get a pipe wrench on it but the rain got me before I could try that…
   / Mahindra 2540 Wont go into gear #17
I am surprised that you could not get full travel of the lever with the cable disconnected, is there a lot of "slack" in the cable movement or a spongy feel. Is the lack of travel the same in both directions?
A small pipe wrench should provide ample leverage to approximate the normal provided by the linkage to the cable.
Was there always a noticeable "detent" feeling when shifting previously?
   / Mahindra 2540 Wont go into gear #18
I agree with LouNY u should be able to move linkage 11 with small wrench . With unpinned the shift lever and cable should move freely. May have to unpin at shift handle end to see if it shift handle or cable.
   / Mahindra 2540 Wont go into gear #19
Poor design. Too much leverage. It breaks at the pivot point. I’ve welded it twice. Third time I designed it differently. Works great but it’s looser but it finds the gear.
So at the end of the day, the linkage cable was bad and had a bad bushing in the lever(the lever is no longer a replaceable part apparently and had been welded back once already and was bent again), but no fixed and back in action. Also gave me a excuse to get a fluids and filters changed and replaced.
Ford 8340 (A53317)
Ford 8340 (A53317)
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
HITACHI EX550LC EXCAVATOR (A58216)
HITACHI EX550LC...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
Swict 72" Bucket (A57149)
Swict 72" Bucket...
