3-Point Hitch Mahindra 2538 owners
   / Mahindra 2538 owners #2
<<<<<<< uses a big ol' fits all wrench, its standard and metric in one tool ;)
   / Mahindra 2538 owners #3
I dont use the lock nut on mine. I just hand tighten the turn buckle and then put the cotter pin in the threaded rod.
   / Mahindra 2538 owners #4
Go mowing through heavy brush, grass or thickets, you will wish you used that lock nut. I used to do the same thing until I lost check chains or check rods, they are pricey!!!! That pin can come right out and vibration does the rest.... before ya know it...... they are gone
   / Mahindra 2538 owners #5
True, like most tractor parts they are high. Most of my use has been with a box scrape and not much with a bush hog yet. I'll use them next time, may start the search for some of the extendable links instead of the pats easy change I was looking at.
   / Mahindra 2538 owners #6
I have a 2540 (shuttle) and find that the stabilizer comes loose frequently when I use a stump grinder (there can be extreme vibration!) I think the next step is top'n'tilt cylinders, and maybe I'll locktite the other stabilizer.
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
2014 MAC CXU613 Semi (A50514)
2014 MAC CXU613...
Portable Calf Creep Feeder (A50515)
Portable Calf...
2803 (A50460)
2803 (A50460)
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
Gehl Mix-All Mill (A50515)
Gehl Mix-All Mill...
