Mahindra 2538 HST cruise control light
   / Mahindra 2538 HST cruise control light #1
mahindra2538hst
Columbus, Ohio
mahindra 2538hst
So my cruise control light suddenly popped up and is not going away... I dont have cruise control lol. It stays on all the time with the machine on or off. Anyone know what might have caused this?
Any help appreciated! Thanks
   / Mahindra 2538 HST cruise control light #2
The 2538 is pre-wired for cruise. The first place I'd check would be where the 2 pigtails are located. First one is down next to the HST pedals, under the floor borard. The second one is inside the dash on the left side of the wheel (upper half). Possible that something got inside the terminal and closed the circuit causing the dash light to come on.
If that doesn't work, check for other wires rubbing against the pigtail (or the indicator light) in the dash. Might have rubbed thru the insulation, making contact.
If you haven't had a software update by your dealer in the last year or so, you might want to get them to do that. That might take care of it as well. Also, mine ran MUCH better after the update.
Sorry, couldn't be of more help. I'm sure some of the experts on here will be able to give you other suggestions.
Let us know when you find out what it is.
Last thing I'd try is disconnecting the negative battery terminal for about 5 minutes, and then re-connect to "re-boot" the computer.
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2020 Lincoln Naultilus SUV (A50324)
2020 Lincoln...
P.T. Canal Pump (A50121)
P.T. Canal Pump...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
91013 (A48082)
91013 (A48082)
