Mahindra 2538 HST/cab AC belt
   / Mahindra 2538 HST/cab AC belt #1
Kambie70
2017 Mahindra 2538 HST
Just took the tractor out of the shed for the first time in a couple of months (had a very mild winter so only needed to blade snow once). Was doing some clean up and noticed a squeal. Checked the engine and the AC belt was toast. Won’t need the AC for a while so is it okay to run the tractor w/o the belt?
   / Mahindra 2538 HST/cab AC belt #2
Perfectly fine w/o.
   / Mahindra 2538 HST/cab AC belt #3
Just to be on the safe side, check to be sure that belt ONLY runs the AC condensor and not something else as well. You probably already checked that, but just in case you haven't...
As far as I can tell it doesn’t run anything else. The manual isn’t the best. I inherited the tractor from a relative and the Mahindra dealer he bought it from in 2017 is no longer in business. Fortunately I haven’t had any problems with it until now so I haven’t had to take it any where since I do the maintenance myself. Closest dealer is about 1 1/2 hour away. Should probably give them a call and start a relationship.
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
