Mahindra 2538 HST/cab AC belt
   / Mahindra 2538 HST/cab AC belt #1
Kambie70
2017 Mahindra 2538 HST
Just took the tractor out of the shed for the first time in a couple of months (had a very mild winter so only needed to blade snow once). Was doing some clean up and noticed a squeal. Checked the engine and the AC belt was toast. Won’t need the AC for a while so is it okay to run the tractor w/o the belt?
   / Mahindra 2538 HST/cab AC belt #2
Perfectly fine w/o.
   / Mahindra 2538 HST/cab AC belt #3
Just to be on the safe side, check to be sure that belt ONLY runs the AC condensor and not something else as well. You probably already checked that, but just in case you haven't...
As far as I can tell it doesn’t run anything else. The manual isn’t the best. I inherited the tractor from a relative and the Mahindra dealer he bought it from in 2017 is no longer in business. Fortunately I haven’t had any problems with it until now so I haven’t had to take it any where since I do the maintenance myself. Closest dealer is about 1 1/2 hour away. Should probably give them a call and start a relationship.
New Idea 6254 Round Baler (A50774)
New Idea 6254...
LOT LOCATIONS (A52141)
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2013 Peterbilt T/A Heil 28Yd Side Loader Garbage Truck (A50323)
2013 Peterbilt T/A...
