mahindra 2516 hst fuel economy
   / mahindra 2516 hst fuel economy #1
70sum
fallston, md
mahindra 2516 hst
New member. I purchased my first Mahindra last fall. I like the 2516 hst very much. loader/backhoe. I traded my Ford 1710 when I purchased the new tractor. Curious as to fuel economy others have seen. The 2516 seems to use more fuel then my 1710 did for the same type of usage. 85 hrs on the 2516. I'm not working the tractor hard, mostly snow removal from driveway. Any ideas of what kind of hrs/gal, etc I should be getting? Thanks in advance.
   / mahindra 2516 hst fuel economy #2
Hi 70Sum!
I have a 2816 which is very close to what you have. Fuel economy I feel on the 28 is great. It entirely depends on what I am doing with the tractor as to what my fuel economy is. It naturally burns more fuel when I bush hog or plow. Some say a gallon an hour is about the norm based on an 8 hour shift. I find that to be almost accurate, but there are times the tractor barely sips the fuel.
One thing to keep in mind is your fuel usage probably will be a little more in the winter than the summer depending on if you are running blended fuel, but it really is negligible.
Nelson
   / mahindra 2516 hst fuel economy #3
I have a Max 22TLB and have never burnt a full tank in an 8 hour day.
   / mahindra 2516 hst fuel economy #4
Due to lower heat energy in winter blended fuel, you will suffer lower fuel economy and loss of engine power.
While plowing snow many machines use a lot of fuel. You have starting up the engine cold, running it hard to plow with, lower btu fuel, spinning tires etc. Are you comparing plowing snow with your previous ford and your Mahindra? Its hard to say what exactly your issue may be
   / mahindra 2516 hst fuel economy #5
I average about a gallon an hour on my Max25 when plowing snow. Like most have said, sometimes more sometimes less. But 1gph is a pretty good average estimate.
I've also found that i get sufficient power while plowing snow with my rpms down in the 1800-2000 range. Rarely does the engine struggle and it seemed to lower my consumption significantly.
-J
2024 Deere 317G (A50123)
2024 Deere 317G...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51694)
2018 Suzuki...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
