Traction Mahindra 2015hst two and four wheel pedal
   / Mahindra 2015hst two and four wheel pedal #1
Becharpa
Bridgton, maine
Mahindra 2015HST
My pedal to put tractor in 2 or 4 wheel sticks in position and i have to pry it to another. It mostly sticks on 4 wheel option. Wondering if linkage or hydraulic issues.
   / Mahindra 2015hst two and four wheel pedal #2
It sounds like you are talking about your differential lock pedal, which has nothing to do with 4WD. There should be a lever under the seat allowing you to shift between 2 and 4WD.
Yes you are right. When i press it down it gets stuck and i have to use force to bring it back up. Thanks for reply.
   / Mahindra 2015hst two and four wheel pedal #4
Try lubricating the linkage.
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2012 Ram 4500 Versalift TEL29N 29FT Bucket Truck (A50323)
2012 Ram 4500...
2007 Ford F-150 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
199049 (A51243)
199049 (A51243)
