Traction Mahindra 2015hst two and four wheel pedal
   / Mahindra 2015hst two and four wheel pedal #1
Becharpa
Bridgton, maine
Mahindra 2015HST
My pedal to put tractor in 2 or 4 wheel sticks in position and i have to pry it to another. It mostly sticks on 4 wheel option. Wondering if linkage or hydraulic issues.
   / Mahindra 2015hst two and four wheel pedal #2
It sounds like you are talking about your differential lock pedal, which has nothing to do with 4WD. There should be a lever under the seat allowing you to shift between 2 and 4WD.
Yes you are right. When i press it down it gets stuck and i have to use force to bring it back up. Thanks for reply.
   / Mahindra 2015hst two and four wheel pedal #4
Try lubricating the linkage.
yellow ball Trailer (A56859)
yellow ball...
skeleton / rock bucket (A56857)
skeleton / rock...
Toro Workman HD Utility Cart (A56857)
Toro Workman HD...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A58018)
2007 FREIGHTLINER...
200 Gallon Tank (A57148)
200 Gallon Tank...
