Mahindra 2015 Top and Tilt Plumbing
   / Mahindra 2015 Top and Tilt Plumbing #1
zendog
I am in the process of installing this set up on my tractor. The tractor already has a FEL. My question is how to plumb the hydraulics. I understand I can use the power beyond on the FEL and put that into the input of the new valve and then utilize a T and run the tank line back to the tank on the hydraulic block. My question is do I need to run another line from the new valve power beyond port back to the power beyond port:confused on the tractors hydraulic block.
Thanks for the help.
:confused:
   / Mahindra 2015 Top and Tilt Plumbing #2
In the normal way of things, the fluid not used by the FEL would go to the 3pt. The PB from the additional valve should go the the 3pt since you broke the connection when installing the new valve. All expended cyl fluid should go to tank.
Reel Mower Tractor Attachment (A50322)
Reel Mower Tractor...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A50322)
2017 Caterpillar...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
John Deere 652R (A50121)
John Deere 652R...
