Mahindra 2015 Top and Tilt Plumbing
   / Mahindra 2015 Top and Tilt Plumbing #1
zendog
I am in the process of installing this set up on my tractor. The tractor already has a FEL. My question is how to plumb the hydraulics. I understand I can use the power beyond on the FEL and put that into the input of the new valve and then utilize a T and run the tank line back to the tank on the hydraulic block. My question is do I need to run another line from the new valve power beyond port back to the power beyond port:confused on the tractors hydraulic block.
Thanks for the help.
:confused:
   / Mahindra 2015 Top and Tilt Plumbing #2
In the normal way of things, the fluid not used by the FEL would go to the 3pt. The PB from the additional valve should go the the 3pt since you broke the connection when installing the new valve. All expended cyl fluid should go to tank.
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2009 PETERBILT 340 (A50854)
2009 PETERBILT 340...
2001 FONTAINE CEMENT POD TRAILER (A50854)
2001 FONTAINE...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
