Mahindra 2015 HST Top and Tilt
   / Mahindra 2015 HST Top and Tilt #1
zendog
I am the owner of 2005 2015 HST, I would ike to install a TnT set up for the box scraper, I have noticed the kits by bare co, my local dealer want 1300.00 to install. I would like to get the parts myself and install it myself.
Any insight would be appreciated.
   / Mahindra 2015 HST Top and Tilt #2
Sounds like you don't have any rear remotes in your hydraulic system. In that case, you will have to re-plumb the hydraulics fairly extensively. I'm hardly the expert on hydraulics. Might try the general forums in the hydraulics section -- usually lots of good info there on what you need to do. It would probably be helpful if you had a photo or two of your existing hydraulics for the loader joystick (you do have a loader?).
   / Mahindra 2015 HST Top and Tilt #3
Check us out. Tractor Hydraulic toplink, Top-N-Tilt, Side link
All cylinders have double piloted check valves.
hydraulic top link is $185
Custom Side link- $250
Joystick valve- $320
You can use a cheaper valve if you want too.
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
3 PT ATTACH SPREADER W/ 12" CHAIN (A51243)
3 PT ATTACH...
Bale Ring (A50515)
Bale Ring (A50515)
MULTIQUIP CONCRETE SCREEDER (A51244)
MULTIQUIP CONCRETE...
Blue Bird School Bus (RUNS)(TITLE) (A50774)
Blue Bird School...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
