Mahindra 2015 HST Top and Tilt
   / Mahindra 2015 HST Top and Tilt #1
zendog
I am the owner of 2005 2015 HST, I would ike to install a TnT set up for the box scraper, I have noticed the kits by bare co, my local dealer want 1300.00 to install. I would like to get the parts myself and install it myself.
Any insight would be appreciated.
   / Mahindra 2015 HST Top and Tilt #2
Sounds like you don't have any rear remotes in your hydraulic system. In that case, you will have to re-plumb the hydraulics fairly extensively. I'm hardly the expert on hydraulics. Might try the general forums in the hydraulics section -- usually lots of good info there on what you need to do. It would probably be helpful if you had a photo or two of your existing hydraulics for the loader joystick (you do have a loader?).
   / Mahindra 2015 HST Top and Tilt #3
Check us out. Tractor Hydraulic toplink, Top-N-Tilt, Side link
All cylinders have double piloted check valves.
hydraulic top link is $185
Custom Side link- $250
Joystick valve- $320
You can use a cheaper valve if you want too.
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
