Mahindra 2015 Dying
   / Mahindra 2015 Dying #1
Outbreak
Mahindra 2015
I'm trying to troubleshoot a problem on my girlfriend's tractor.
It's a Mahindra 2015 with the 3cyl diesel with a Bush Hog mower. It has sat all winter.
About two weeks ago, we jumped it, and mowed for 4+ hours without any issues. A day or two later, topped off with fresh diesel, I began mowing again, and after about 20-30min, it began to slowly lose power. I disengaged the PTO, but RPM didn't come back up. Any additional load (acceleration, raising the mower) caused RPM to drop further until it died.
After that, it would turn over, and even start but only run for about 10sec. We let it sit for a few hours, and it ran long enough to get back to the garage.
Since then, we've changed the fuel filter, added an anti-algae additive. I ran it with the fuel cap off, covered by a rag to make sure the fuel tank is venting. Oil and coolant are at appropriate levels, and the temp gauge appears to be working properly, and is right in the green when the issue occurs. Same thing keeps happening. It runs great for 25 min (I timed it yesterday) then slowly dies over about 90sec. After it died I turned it off and back to the on position, and the fuel pump was still audible.
I have some mechanical ability, but I'm not very experienced with tractors or diesels, so I'm just trying to give as much information as I can in hopes that someone can give me an idea I haven't thought of.
Thanks in advance!
Outbreak
   / Mahindra 2015 Dying #2
I had a similar problem with my 2615. there was enough crud that some of the passages in the fuel filter housing had plugged. Mine came apart real easy to clean. I found the problem by removing the infeed fuel line and making sure it had flow, putting it back on and removing the outfeed line which had no flow.
If there was a lot of crud in the tank the filter could be plugged again
Good luck
Tom
   / Mahindra 2015 Dying #3
Not sure about the 2015, but my Mahindra has 2 different fuel filters. One on each side of the engine. Check to see if perhaps you have 2 filters as well.
   / Mahindra 2015 Dying #4
I had to drain the tank and remove the fuel line coming from the tank. You should find a little screen filter. Mine was clogged, and once I cleaned it she ran flawlessly.
I hope your problem is as simple as mine.
   / Mahindra 2015 Dying #5
Draining the tank is listed in the manual for my 2615. I think it is a 50 hr. service item.
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2018 Ford f150 (A50323)
2018 Ford f150...
UNUSED JCT SKID STEER QUICK ATTACH CONCRETE MIXER (A51244)
UNUSED JCT SKID...
2008 Wilson Hopper Bottom Trailer (A50514)
2008 Wilson Hopper...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
