mahindra 1626
/ mahindra 1626 #1
textedford
mahindra 1626,ford 8n
hi guys i have a 2021 1626 my book says there is a fuel shutoff to change the fuel filter i can't find it help thanks tex.
2021 1626.
1950 8n ford.
/ mahindra 1626 #2
I don't know about your tractor specifically, but usually the fuel shut off is right next to the housing for the fuel filter. Just a little tab thingy you flip 90 degrees to block off the line.
Edit: this video (not me) says the fuel line shuts off automatically
/ mahindra 1626
hi seville009 thanks alot both my books say there is a shutoff valve in it thanks again tex.
/ mahindra 1626 #4
there is a shutoff valve......I guess it's just automatic vs manual.
From looking at the video though, looks like you get a pretty good amount of fuel leaking in the process anyway.......might want to wear some gloves
/ mahindra 1626
yes i see that found a big funnel to go around there after i get it started off thanks again tex.
/ mahindra 1626 #6
if its the same as the 26, removing the filter stops the fuel flow
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
New Holland 3930 (A60462)
New Holland 3930...
