HF sells a cheap (under 3 buck) terminal and post cleaner. I have a couple and use them regularly.
Jan 21, 2022 / Mahindra 1626 will not turn over #11 5030 Epic Contributor Joined Feb 21, 2003 Messages 24,751 Location SE Michigan in the middle of nowhere Tractor Kubota M9000 HDCC3 M9000 HDC HF sells a cheap (under 3 buck) terminal and post cleaner. I have a couple and use them regularly.
Jan 21, 2022 / Mahindra 1626 will not turn over #12 Ledgemere Farm Veteran Member Joined Apr 29, 2002 Messages 1,855 Location Limerick, Maine Tractor A bunch Did you find the problem ?
Jan 22, 2022 / Mahindra 1626 will not turn over #13 E English Rugby Fan Member Joined May 21, 2017 Messages 40 Location Morriston Florida Tractor Mahindra 1533 I have a 1533 regular shift and had terrible battery corrosion problems starting was a nightmare then I discovered on Amazon new battery terminals made of aluminium. They have worked out better than first thought. Picture and product below. TONWON Battery Terminal Connector,12-Way Connectors 8AWG up to 4/0(XL) AWG Lead-Acid Battery Terminals for SAE/DIN/EN Tapered Top Post SDEA-12 https://www.amazon.com/dp/B08HJXY9FF/ref=cm_sw_r_cp_api_glt_i_9AMSCT90YJ684DVQ7XGX.
