Mahindra 1526 starting issues.
   / Mahindra 1526 starting issues. #1
Kaah2001
Mahindra 1526 HST 2016 model
Issue started about six weeks ago. Hard first start of the day. White smoke. Gotten progressively worse. Today would not start even with a jump from my truck. Battery was tested a month ago and appeared fine at the time.
Thoughts?
   / Mahindra 1526 starting issues. #2
What have u tried.??
I think they have an electric supply pump.. when you turn the key to on, u should hear it clicking..
Have u changed the fuel filter.??!!!
Try loosening the inlet connector on the injection pump and turn the key on.. there should be a flow of fuel THERE..
Good luck.
   / Mahindra 1526 starting issues. #5
Battery terminals.
And check the glow plugs if it has em
Glow plug based engines typically need them replaced
If it has a grid heater, check its powering up. Typically the outside of it will be hot after it cycles and you can check without taking anytning apart
My buddies modern mahindra has electrical gremlins caused by a chafed harness behind the dash.
   / Mahindra 1526 starting issues. #6
Unplug white connector an front of first glow plugs. Use sandpaper to clean it off. Put some dielectric grease on it.
   / Mahindra 1526 starting issues. #7
I did have mice chew on wires behind instrument cluster on top of fuel tank.
   / Mahindra 1526 starting issues. #8
Just had the same issue. The start up was blowing a little white smoke and progressively got worse to where it wouldn't start and just blow white smoke. Took the test light to the first plug and would the light to come on sometimes, put the test light to the wire that connects to the first glow plug and had power. Turns out the fuseable link that send power to the bar went bad, it connects to the first glow plug and you could see it was melting a little bit. Went to the auto parts store and bought a fuseable link and she fired right up! $8 at NAPA
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2021 International HV507 12ft Dump Truck (A51692)
2021 International...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2013 CATERPILLAR...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
2015 John Deere 310SL (A47384)
2015 John Deere...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
