magnum 20 to command 20 .. has anybody made the swap ? ?
   / magnum 20 to command 20 .. has anybody made the swap ? ? #1
patp744
Bronze Member
pittsburgh
terramite t5c
I finally broke down and bought the command 20 replacement motor . and the new wiring harness from terramite .
has anybody made the change yet ? any pitfalls ? things to watch out for ?
   / magnum 20 to command 20 .. has anybody made the swap ? ? #2
Looks like you will be the first. Keep us posted on the swap.
Will do...
trying to make sure a have EVERYTHING I need before I start..
20 hp. Command =1700.00
20 amp. Up grade (stock 15 amp) and tac. = 120.00
New key switch and wiring harness from Terramite. 140.00
new throttle cable and choke cable , like 80.00 (still waiting for them to show up) :(
Oh bty. If you have the skinny back tires like I do . 9.5x 16 ..and want to go to the 13 inch wide it's 495.00 each . Rims come with tires .. no exception. . B.S..!!
Oh...btw
i did the motor change , in my driveway at home . I took out the old engine on a Friday night took maybe a little over an hour , and had the new one in and running just before 8 Saturday morning , good morning neighbors. .!.!.
the hardest part was the engine coupler , I have the universal style like on a truck drive shaft. Thanks to some oil and a 6' digging bar I was able to pop it off the old engine with out having to remove the hydraulic pump..
now..getting it on the new engine is a different story ..
if you don't have the exhaust on you have just enough room to set the new engine in sort of sideways , this give you room to get one hand in there to line up the coupler on the shafts .then gently straighten out the engine and tighten the grub screw , and your done .bolt the engine down , fill with oil , the electric hook up was easy , and turn the engine over to see if you have any wobble in the coupler....BUT.... I would remove the two plastic caps in the exhaust ports first...or they shoot across your driveway into the garage with a loud bang ..
oops..lol..
I do have some pics and I'm trying to figure out how to put them here from my phone .?!?
Huh..well it looks like I can send pic from my phone .
crap.
PRORUN GAS POWERED WEED EATER (A50460)
PRORUN GAS POWERED...
2009 Gleaner A76 combine (A50657)
2009 Gleaner A76...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2 Saw Horses (A48837)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2015 Hyundai Elantra Sedan (A48082)
2015 Hyundai...
