Magnetic ground clamps
/ Magnetic ground clamps #1
Harry in Ky
Elite Member
Winchester Ky
Allis Chalmers ED 40
Does anyone use or have any experience with a magnetic ground clamp? I see a number of them listed online, some are switched, some not. I wondered if anyone has tried one, and if so, what do you think of them?
/ Magnetic ground clamps #2
I have used one with a switch that normally works well on larger projects. Under certain conditions, it is possible to knock it off.
Ken
/ Magnetic ground clamps #3
I have a smaller one that is swiched.
I use it for things that I can't get a grip in with a regular work clamp.
Works ok. Only trouble I've had is with some arc blow when TIGing some small sheet metal parts.
My favorite work clamp is a pair of vise grip pliers. I welded a bolt to the side to attach the cable.
They can grip from 2.5" pipe to sheet metal. Can't find the pair I have at home or I'd post a pic.
OK. Found them. Model:12LC
/ Magnetic ground clamps #4
I bought and tried one like this. Don't waste your money.
/ Magnetic ground clamps #5
Agreed. I bought one of those things too and even bolted it to my ground clamp which was a mistake. It was very hard to remove after only one use - durned stud just wanted to spin and the theads had melted some making the nut impossible to get off. Finally cut it off. Total waste of money.
Yes, I've seen this type, and wondered if the small contact surface that conducts the load would be a problem - poor conductivity/heat build up? Can't tell from the photos of the switched type because the photos don't show the business end.
/ Magnetic ground clamps #7
Have used them in the past, the boss had it set up that way and it worked well. just won't work on aluminum. I am setting up a welder soon and just might use one. Thanks.
/ Magnetic ground clamps #8
What I have found is they are not worth a flip for field work. The big issue is the spring involved, heat, and failing sooner than later. It's one of those ideas that sound great but in reality isn't.
/ Magnetic ground clamps #9
The ones with a switch like a mag mount for an indicator gave a large surface area and do not have the problems the cheap ones have. But they can affect your arc.
Ken
/ Magnetic ground clamps #10
I've sold a bunch of the switched ones but you need the 600 amp one to get a good magnet. The problen is the price. $60.00. I use one when I have to but only then. They work good on pipe but you have to keep the arc away from the magnetics., They work best for holding up a Christmas Wreath on my steel siding.
That's pretty much what I expected. Other than pipe or large surfaces with few edges to clamp onto, the concept seems more novelty than practicality.
2014 Ford Econoline Van, VIN # 1FDEE3FL6EDB17703 (A61165)
2014 Ford...
2007 Acura TSX Sedan (A61569)
2007 Acura TSX...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
GAS BOY DIESEL FUEL PUMP (A62131)
GAS BOY DIESEL...
208316 (A58375)
208316 (A58375)
Agline ADM109 Disc Mower (A64047)
Agline ADM109 Disc...
