Magnatrac with new power plant
   / Magnatrac with new power plant #1
LXT
PA
too many to list
Well, last I posted the Kohler engine was giving me some issues so i decided to put a new power plant in the machine. HF was having a great sale on the 22 hp Predator motors so for $849 I bought one. this required some modification to the "firewall" area of the machine, some longer Hyd hoses a coupler with mount and a little modification here & there.
I did have a buddy fab me up a guard to cover the Hyd motor & it's on (just no pic) any way I have been running the predator for 2+ months now & so far so good, power wise no difference & the fact that I dont have to worry about the engine just stopping in the middle of a job is a plus. this is an older machine & I have done a lot of work with it, last year graded for above ground pool for granddaughter, moved and spread more #4 rock than I wanted to & am currently digging out to put in a basement door (will post pic), so I need this lil guy for the foreseeable future and a new engine will mean more projects get done (momma will be happy) - Just thought I'd share in case someone out there was interested.
My current project, I have dug it down more & had to switch over to the front loader hoe to reach down deeper, now I have around 25+ tons of dirt on the side to deal with - LOL, gonna put versa Loks on each side to retain and paver walk with versa lok steps - this will be an all summer job, im currently figuring the drainage aspects out on this project , I now at the footer & founf the old terra cotta french drain - doesnt look to be a working french drain???? I have the interior french drain in the basement so not sure what to do with what I found.
gonna put in a trough drain and feed any accumulated water to a sump & pump it to the yard, might tie the terra cotta in to this system - if any one has done this................... advice would be greatly appreciated.
   / Magnatrac with new power plant #3
I have never understood how you keep water out of a basement. Don't have anyway to learn around here because almost nobody has a basement!
David from jax
   / Magnatrac with new power plant #4
Build it like a swimming pool in reverse and if grade is with you a drainage system to daylight for backup.
Had a home once with a sump which did a great job until the power went out and 6” of water pooled up…
Had a plan to drain from sump to daylight but got an offer too good to pass up so sold the place… with a new sump pump of course.
Ultrarunner,
Yeah, no power would be a problem - can't ditch pipe to daylight as the elevation is too low & I dont think my neighbor who owns the property I'd have to evacuate out onto would like that, as well I have Electrical id have to ditch under.
I'm trying to put the door in to have all swimming pool users go into the basement to use the rest room instead of using our upstairs restrooms - kids ya know. I'm retaining the wall with versloks & going to put in pavers with pitch away from door to a trough drain which will basically back feed the water to a sump basin & pump to send water through Sch 40 - 2-inch pvc behind the wall to evacuate to daylight in the yard driveway area.
I really dont see any other options, I'm good with the hard scape as I owned a tree & Landscape service for years & did many projects (working for utility now). but im not a drainage expert, I've worked with some & watched what they did but doing with knowledge is different than doing with hope that it will work & that's what I'm going through. I've mentioned this plan to many & I've gotten positive feedback so we`ll see!!!!
Ill update as I move forward - as for the machine - runs like a champ & the front loader trenching Hoe has helped big time, I know many on here kind of laugh & think it's a toy but I'll tell ya its better than a shovel & surprises many that I know, it's a niche piece of equipment for sure - my biggest problem is people who want me to do jobs for them that they can't find anyone with a machine to access their project to do it all the while I'm doing my own projects & dont have time.
watch....... I'll have time and no side work will be available, LOL
Well Thought id provide an update, got all the hand work done and the drain / evacuation lines (2inch PVC 40) a buddy of mine is a hydro geologist and I presented him my idea which turned out he thought was pretty good (imagine that).
Had to use the magna trac to widen the area by the door for the sump, I've gotten further recently & am getting ready to install the door within the day or two, cleaning out that was a PITA but I parked the machine up top & hand loaded the bucket, no matter how small the machine there is always hand work when digging. ill keep updating as I go but thankfully I got the machine to get it done, just the aggregate, cleanup and other odds n ends the magna trac does pretty good.
thought id update the progress on the project
so got the door in, started the block work - got all the plumbing into the sump and coming out of the "hole" as I call it, trenched the wall extensions with the front loader hoe, does pretty good not the first choice but better than by hand, ive gotten much further but not really a picture taker.
The magnatrac has been awesome & the new predator engine is doing good, Ill update soon with more progress. Hope this gives some idea of what these machines can do, sad part is I cant capture everything and work at the same time.
Realized that I have a bunch of pictures posted but none really show the machine, so figured I`d put some up, this is an older Magnatrac early 2000`s the enclosure was on it when I got it years ago & im glad for that - cant tell you how many times that cage has saved me from some #4 slinging out of the bucket & bouncing off the cage instead of my head (Lol)
I put the box over the ballast which holds some tools in case you get in an area & need to wrench on something, a beer holder and some LED lights for this time of year cause its dark at 5pm in PA. Not the prettiest machine but it does do some work. I dug that whole area out with this machine and with the dump trailer in close proximity you can do some fast work for what is a slow machine. that's the key to its use, I use the machine & dump trailer in tandem when needed to move earth or gravel - much faster to load 3-4 tons and move it with trailer than solely with the magnatrac.
the front plate you can see (bright yellow) or i should say hydraulic pump guard has been a saving addition, ive bounce rock, dirt & have bumped the trailer with that guard - without it im sure it would have been expensive damage. so there ya have it, a break down of a pretty dam good machine that I plan to have for many years to come - cause i cant justify buying a new one or I would... Happy Turkey day everyone!
got the other trench dug - snow has rolled in and im thinking my project will be on hold for a while, any way here is the crawler with the FEL hoe attachment, it's a more useful tool than I thought it would be. Im probably a PITA with my posting but I always hated when someone started a project and never continued to post until done. so any Magnatrac guys out there what attachments are your favorites?
FIMCO SPRAYER W/ WAND (A58374)
FIMCO SPRAYER W/...
SHOPBUILT T/A TRAILER (A52708)
SHOPBUILT T/A...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
GRAIN AUGER (A52708)
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
