Magnatrac Crawler Engine Specs - Kohler
   / Magnatrac Crawler Engine Specs - Kohler #1
Pete1961
Telford Shrops
None
Hi, I have been looking at the Struck hydro crawlers for a job on slopes, at different times they have used Kohler Command pro, B&S Vanguard, & now Honda GX 680.
I have checked the max angles the engines can work at, B&S 15 deg constant, up to 30 deg intermittent (however B&S will not define intermittent.) Honda GX 680, 20 degrees, Kohler 25 degrees.
I cannot find from where I am if the Kohler max angle is a constant rating, specs do not say, there is a toll free phone no - but this is not practical from overseas. I cannot email them as their site does not recognise my phone no or postal code.
On the face of it the Kohler seems the best engine for slopes, & all the owners using them on steep grades seem to have the Kohler powered MH 5000 anyway.
They have brought out a true dual path hystat - the new 4900, sadly it has the Honda, the Kohler would give me an extra 5 degrees, so I would never push it to the max.
As far as I know all the engines are gasoline carburated - not EFI or LPG - as they like to keep the machines simple for the home mechanic.
If anyone has a Kohler Command in something else - they might know the answer to this. Thanks, Pete
   / Magnatrac Crawler Engine Specs - Kohler #2
Don't know the specific model number that Struck uses, but saw several references to 25 degrees, like you mentioned.
http://www.kohlerengines.com.cn/onlinecatalog/pdf/24_590_27.pdf
Kohler Engines: CH26: Command PRO: Product Detail: Engines
   / Magnatrac Crawler Engine Specs - Kohler #3
Would someone comment on the effect, good or bad, legal or illegal, of using a 2 stroke oil mix in a 4 stroke air cooled engine. Someone I know does this when mowing a severe slope with a push mower and the mower is still running.
Thanks Xfaxman,
This is pretty much the info I have seen, wish I could find out if the 25 deg is short term only or continuous. I was thinking of asking Struck if there could be a suitable Kohler option on the 4900, Otherwise the 5000 & 4800 models used Kohler 25 Hp.
The 4800 went on much later & included the 5 bottom roller track frame (but only 3 rollers were fitted per side) It though has a single gear pump doing everything. My idea was to refit with twin pumps as the 5000 & others had - to give me the 2 speed overdrive. There are often low hrs 4800s come up at not bad prices. All the hydraulic info & diagrams is published in online manuals
I have also been looking into the Boxer stand on tracked - but this has no brake other than the hydraulics.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Galvanized steel fence (A53424)
Galvanized steel...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
