mag heater: oil breakdown?
   / mag heater: oil breakdown? #1
big bubba
Elite Member
arkansas
M8540
Members: Am considering a magnetic engine heater (tr. supply co) for those extreme cold days for tractor startup. It is advertised to operate at 300-400 degrees F If I apply it to the bottom of the oil sump pan, will there be an issue of oil breakdown if plugged in for a few hrs before startup? What's the engine oil operating temperature on a diesel rig anyway? thanks in advance bb
   / mag heater: oil breakdown? #2
I used to use the engine block heater that came installed on the two diesel trucks I have owned for 4-8 hours before starting. Four hours should be enough time though. My heater was/is around 1500 watts so a four hour warm up costs 60 cents. Do that 30 days a month and that is getting expensive.
So I stopped.
I put in a 5w40 oil in the truck and tractor and don't heat the oil anymore. The truck starts much easier. So does the tractor. Going to try a 0w40 oil since it was not much more than the 5w40 oil.
I never bothered heating the tractor oil. Usually it has warmed up enough outside by the time I start to work that its not too cold unlike the truck which gets started before dawn.
Later,
Dan
Thanks Dan, just now changed to Rotella 5/40 synthetic after 150 hrs break in on the new tractor....you might be right, a heater may be overkill. Just want to do all I can when it's 20 degrees on a tight new rig thanks bb
20711 (A50323)
20711 (A50323)
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
2017 INTERNATIONAL PROSTAR (A52472)
2017 INTERNATIONAL...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
KMC 5610 (A53084)
KMC 5610 (A53084)
