mag heater: oil breakdown?
   / mag heater: oil breakdown? #1
big bubba
Elite Member
arkansas
M8540
Members: Am considering a magnetic engine heater (tr. supply co) for those extreme cold days for tractor startup. It is advertised to operate at 300-400 degrees F If I apply it to the bottom of the oil sump pan, will there be an issue of oil breakdown if plugged in for a few hrs before startup? What's the engine oil operating temperature on a diesel rig anyway? thanks in advance bb
   / mag heater: oil breakdown? #2
I used to use the engine block heater that came installed on the two diesel trucks I have owned for 4-8 hours before starting. Four hours should be enough time though. My heater was/is around 1500 watts so a four hour warm up costs 60 cents. Do that 30 days a month and that is getting expensive.
So I stopped.
I put in a 5w40 oil in the truck and tractor and don't heat the oil anymore. The truck starts much easier. So does the tractor. Going to try a 0w40 oil since it was not much more than the 5w40 oil.
I never bothered heating the tractor oil. Usually it has warmed up enough outside by the time I start to work that its not too cold unlike the truck which gets started before dawn.
Later,
Dan
Thanks Dan, just now changed to Rotella 5/40 synthetic after 150 hrs break in on the new tractor....you might be right, a heater may be overkill. Just want to do all I can when it's 20 degrees on a tight new rig thanks bb
John Deere 6125M (A50120)
John Deere 6125M...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
Claas Rollant 350 Round Baler (A50774)
Claas Rollant 350...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
