made some new brush forks
   / made some new brush forks #11
Hey fbrk8r nice work I like your design. How long are your forks and did you use angle iron for the cross braces?
Thanks! The forks are 48" long total. About 36" or so sticks out from the bucket. And yes, that is angle iron.
   / made some new brush forks #13
Did you close up the end of the tubes? I'm guessing so, otherwise they'll fill up with dirt and rust out right?
What size bolts did you use to bolt them in the bucket?
Add this to the list of things I gotta build / do.
Yeah of course the tips are sealed up. I welded a small piece to seal them up and the ground them smooth. I can't remember the bolt size. I think they were grade 8 and 7/16".
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
1984 HUDSON BUTLER 95" X 18'PINTLE HITCH TRA TRAIL (A52708)
1984 HUDSON BUTLER...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
Rears MTG Co 105G Stainless Steel Pak-Tank (A59225)
Rears MTG Co 105G...
