Made my first implement tonight. WHAT a POS!
   / Made my first implement tonight. WHAT a POS! #1
yelbike
Near Winnipeg, Mb, Canada
John Deere 2305, 2320,Z465
I spent some time this evening trying to set up a drag harrow on the back of myTSC carry all. Well it did work out very well at all. I took it for a test spin. The darn thing digs in a the front. I adjusted top link but things did really go any better.
Useally I'd look where to improve on a design, I'm looking to start over I think.
Oh well, better to have tried and failed than not to have tried at all.:cool:
   / Made my first implement tonight. WHAT a POS! #2
It sure looks like it should work. The top link will have to be set especially long to keep the pipe from digging in. The pipe should be barely skimming the soil. You may even need a longer top link.
Did you lower the 3PH all the way or was it set to float a bit above the ground? Try that and see what happens.
Can't tell from the photos but are the lower arms of the carry-all attached firmly to the drag? Maybe securing the arms at several points with bailing wire would make a difference.
   / Made my first implement tonight. WHAT a POS! #3
I agree. I'm no expert on stuff like that but it looks like it just needs some adjustment to work perfectly.
   / Made my first implement tonight. WHAT a POS! #5
Should work like this.
   / Made my first implement tonight. WHAT a POS! #6
   / Made my first implement tonight. WHAT a POS! #7
At least you tried...now try again, you'll get er done.
   / Made my first implement tonight. WHAT a POS! #8
You should have seen my first drag I made its actually right were I pulled it and left it, still mow around it,the grass is really good were it lays.I told myself its time to scrap:laughing:
I did make one that works pretty good but its to pull around on the 4wheeler,call it the TURD BUSTER
   / Made my first implement tonight. WHAT a POS! #9
They work good as a tire buster too, if you leave them upside down..
   / Made my first implement tonight. WHAT a POS! #10
I think if you look you will see the common thing with all of them and that is a flexible chain at the pull point which allows the pipe to ride up a bit but still contact the ground.
If you will put in about 4 feet of pull chain and attach to each side of your pipe, then I think it will work. It will maybe work better if it comes to a V in front with a single hookup point but dual hook up point should work also. It just needs some flexibility at the pipe and not a heavy load on it.
Heck I think you may be pulling it backward. Try it with the pipe bringing up the rear and attach your pull chains directly to the spike tooth harrow. I think that will smooth things out nicely. Just have a few chain links between the harrow and the pipe so it can flex as needed.
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
1043 (A50459)
1043 (A50459)
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
