M95s DT front axle oil level?
   / M95s DT front axle oil level? #1
Harry in Ky
Veteran Member
Winchester Ky
Allis Chalmers ED 40
Any thoughts on the proper way to fill/check the fluid level(s) in the front axle? There are plugs on the center housing, a fill port and a smaller (level plug I assume) just below that. There are also plugs on each of the front axle cases. These ports are quite high on the cases and seem to me that a fluid level in that high in each axle case would be too high. The parts book shows seals on each differential shaft, which evidently separates the fluid in three compartments. Center housing and two axle housings. Am I wrong in this assessment?
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2013 HINO 388 (A50854)
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
