5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,780
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Well, Having the 5030 and the M9 was too much for me so I traded the 5030 in and now just have the M9 as far as Kubota's.
I optioned the M9 all the way out (as usual). Nice tractor. I understand the Kubota is discontinuing the M9 in favor of the new M93 which will look like the 105-125 asthetically. I had to order the M9 and it took about 2 months for the build and delivery. I also use a 105S and I prefer the square hood of the older M9 over the sloped hood of the M105-125 so when I found out the production was ending, I ordered the M9. Kubota extended the 84/4.99 past the campaign date so that I was able to participate.
For the Junkies:
R1's, 16.5x34 with cast factory weights on the rear
LA1215 loader with ATI quick attach and Kubota pallet forks
8+8 with creep option for 12x12
Hydraulic shuttle
540/1000 option (on order)
am/fm cassette radio (Kubota)
front and rear worklights, wipers and defroster grids
external implement plug
2 sets of remotes + flow control
Grammer air ride seat (thank goodness) (5030 was a kidney buster)
I used the M9 for shuttling round bales of corn stalks this last weekend (used for bedding). The M9 handles 1 round on the back and TWO rounds, one on each fork in the front, no problem. The rounds are 4x5's and weigh about 900 each. Road speed is important to me as a "road" farm (our fields aren't contigious with each other). The M9 will make 22 at rated rpm whereas the 5030 would do about 16......every little bits helps. My 1085 Massey will run around 27 at rated rpm. That's scary even in a 11,000 pound tractor. The main trans is all synchro so I can make clutchless shifts (just like my big truck).
The M9 is nowhere as agile as the 5030 was, but the ride and power is light years ahead of the 5030. I had the 5030 listed here in the classified's but not much interest so it's gone to the dealer.
I got 23K for the 5030 and the M9 was right around 45K.
No pictures.....Everybody knows what an M9 looks like. Not the kind of unit for mowing your front lawn with though you probably could demolish your garage pretty handily.
Maybe I should change my user name to something more appropriate.
I might add that I considered a TN90 CNH as well as a Kioti DK65 (I like the Perkins engine, they are about bullet proof and are very fuel efficient), but the DK hasn't enough suds for a rounder and they discontinued the square hood and the TN90 has the slope syndrome as well as a price tag (on "A" plan), higher than the M9 when optioned almost the same. I know CNH touts their Supersteer, but the wheelcut on the M9 is extreme....no supersteer needed or wanted for that matter.
I guess the sloped hood is fine for most, but I always use the square hood to line up my rows. I am a "hood" man at heart, trucks or tractors.
For the Junkies:
Hydraulic shuttle
