5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,772
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
I don't believe there are too many posters here that have big tractors like I do, but here's hoping someone has some expierence or can shed a little light on my leak.
My M9 (which is still under warranty, but I need it right now) has a leak. Transmission fluid is leaking from somewhere under the cab on the top of the transmission case. It looks like (hard to see under there) it's leaking in the area of the flow control shaft which extends into the cab to control the downward rate of the Three Point Hitch. It's running down the side of the case, across the fuel crossover and dripping from the bottom of whichever fuel tank is lowest. I believe it was leaking last summer too as I kept smelling hot SUDT. Hot SUDT has a peculiar sweet smell but I never saw the leak because one, the tractor was in the field and two, SUDT is clear. At my 100 hour change I switched to 15 gallons of Chevron full synthetic which is oddly, orange. Now I can see the orange trail, especially on the snow. It's not a big leak, but it's a leak on a new machine. With 15 gallons in the sump, I'm not worried about running it dry. Matter of fact, since changing it last fall, even with the leak, it hasn't dropped very much on the dipstick (which, by the way the level is easy to read now because the fluid is orange). I alerted my dealer this winter and they will come out and get it when I can spare it but, if it something I can rectify myself (like a loose bolt or hose clamp), I'll make it a DIY project. I cruised through the dealers shop manual and found nothing and there are no service bulletins pertaining or adressing case leaks. My M105 is basically the same case, but slightly different and of course, it don't leak. With the fluid costing 130 bucks a pail, I don't like the idea of keeping the dust down on the road. Any ideas outh there?
