Dirt Moving M7060 Frame Not Strong Enough For a Toothed Bucket?
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #12
In defence of the dealer AG tractors are not build heavy duty enough to handle the loads of construction duty equipment . Yes it will work but you will wear out your pins and bushings pretty quick.
Adding 6 inches to the front of your bucket puts a lot more strain on your loader and tractor.
I'd be willing to bet that used tractor shown in the photo with a toothed bucket will have a lot of slop in the loader especially if it's been used a lot.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #13
With all the above said, an FEL isn't your best tool for digging but can be used for light removal of dirt. Other attachments are much better for digging.
+1. As one salesman pointed out to me years ago, it is a LOADER not an EXCAVATOR. But I don't think a M7040 has the power or the traction to really get into trouble. Of course that assumes you are taking things slow and easy, not getting a run and jabbing it into rock.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #14
agree with the idea that in general, fel's are not meant for excavation. more for moving loads, etc....but, disagree with idea that the tooth bar alone will put a machine at risk.
in fact, the case might be made that having a tooth bar might slightly ease the stress of taking a shallow cut since it aids in digging....maybe like using a round vs square nose shovel digging a hole.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #15
Agree. You will run out of traction and ability to produce force long before you run out of loader frame or tractor frame which ever they meant. Your Kubota loader is very stout and you are not at risk at all. I think Bubba has a perfect analogy in square nose vs round nose shovels. I think if you are trying to cut down hard packed clay , in reverse with the bucket nose down, you are a whole lot more likely to bust something. And the teeth tend to make that easier, not harder. Take it easy on the parts guy -- he has almost certainly been instructed to cover the Kubota ***. Just doing his duty.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #16
Should be fine, just don't get stupid, like prying from the bucket edge, "Ramming speed" etc.
One of the reasons I've not wanted a tooth bar on my Max28.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #17
This thread brings to mind another that sparked my interest. As I remember it someone said that utility tractors were not rated for digging. I'd not thought about it before.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #18
If the parts person is at dealership you work with I would asking him again and if you get the same answer ask what that is base upon. He could had models mixed up, he could have had a bad thought process on that topic or he have seen damage done with that setup.
   / M7060 Frame Not Strong Enough For a Toothed Bucket? #19
Just remember it's more of a shovel, not a pic axe. Especially with these EZ removable loaders. Look at the older farm loaders and they had a rather large support at the top of the boom mounting area, running usually downward to a heavy support at the front, much heavier built but it did not remove easily (or at all). Like all machinery, just gotta use common sense. If you've ever "snagged" a root or big rock with a tooth bucket while poking along at even walking speed……. I think the part's guy has some merit, especially dealing with the general public. Search TBN for guy's that wonder why their bucket no longer sit's flat on flat ground. It does happen.
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
UNUSED FUTURE 72" CLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 72"...
UNUSED RAYTREE RMBD50 50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
LOOK! (A53485)
LOOK! (A53485)
2016 Ford F-350 Knapheide Service Truck (A55852)
2016 Ford F-350...
UNUSED I/A 12F 12' HYD BOX SCRAPER (A57192)
UNUSED I/A 12F 12'...
