m7060 engine warning 50% power reduction
   / m7060 engine warning 50% power reduction #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
Happened after a parked regeneration cycle, it speeded up for about 20 minutes then came back down and we went back to work.
engine warning blink a few times
now stays on reduced power 50%
no buzzer
Dealer says they have to pick it up
   / m7060 engine warning 50% power reduction #2
Well that sucks. Too bad they couldn’t just hook the computer up there and let ya know what it may be/ do a reset and be on your way with any luck.
Keep us posted....
   / m7060 engine warning 50% power reduction #3
Kubota, like Deere, uses a proprietary ecm hookup that only accepts a Kubota Diagmaster scan tool and you cannot buy one. Dealer only item which is why I won't own a post 4 Kubota. Both mine 2002 and 2004 M9's are totally mechanical. Both make in the excess of rated pto power and both are trouble free and have been since new.
   / m7060 engine warning 50% power reduction #4
I wont own any equipment that only a dealer can repair......at a huge cost. I have heard horror stories about JD equipment.
My operator doesn't like to keep the rpm's up. So after the dealer does a forced regen I will have to come up with solution, I'm thinking at end of each day maybe I'll raise the rpm's and let run for 20/30 minutes to burn off soot, then do a shutdown.
   / m7060 engine warning 50% power reduction #6
Start handing your "operator" the repair bills.
   / m7060 engine warning 50% power reduction #7
For my information - what exactly is "raised rpms" for your M7060, Roy? X rpms for X time. Thanks
   / m7060 engine warning 50% power reduction #8
There are ways to “deal” with the DPF and as a bonus, the egr. Costs a few grand but as another bonus you can get an extra few HP and better fuel economy...... once out of warranty I plan to look into it. My VW TDI has been happy breathing easier.
   / m7060 engine warning 50% power reduction #10
Tell him if he don't run at rated RPM at least part of the time, you'll fire him...........:laughing:
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
Hydraulic Breaker Excavator Attachment (A49461)
Hydraulic Breaker...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
