M7060 8 speed versus 12 speed
   / M7060 8 speed versus 12 speed #31
Could be. Here in Portugal specifically, "real" farming starts right at 50HP or even slightly less. A lot of people with small farms to sell at local markets at what not, don't really need an huge tractor, specially since a big tractor can't go where the smaller ones can.
All kinds of tillage tools, trailers, etc, just in a smaller scale.
That's why we also have higher HP tractors offered in a very small package. For instance, a Goldoni S110 offers 102HP in the size of a Kubota L60 series, or even slightly smaller and it has a 24x12 transmission. Same goes for several other specialized tractors available.
Roading tractors is a just something we have to do a lot, regardless of the size of the tractor, this also includes pulling fully loaded trailers all over the place. Right now, it's grape harvest season, so you would see all kinds of tractors on the road fully loaded with grapes. Even smaller 2 wheel tractor with a trailer.
What's interesting here in Portugal, is that the upper half of the country, can't really use a tractor much bigger than a conventional 150 to 200HP. Anything bigger, it just won't work anywhere. Lots of tight roads, small fields, hills, etc.
On the bottom half of the country, we have JD 9RX's working there, Fendt 1050's, Valtra S series and more of these bigger tractors since the country is a lot more flat and open down there.
By the way my use of "real" was more to define large acerage farms and not insulting anyone working their tail off on smaller farms. 👍
   / M7060 8 speed versus 12 speed #32
I got the point. 👍
People here typically don't have huge fields, at least in the upper half of the country, but have lots of smaller ones spread all over a small village, hence why we road the tractors a lot too.
In the bottom half? Huge fields, albeit, mostly intensive olive, avocados and orange tree plantations, which requires entirely different types of tractors.
Sorry OP for derailing this thread slightly. I'll stop now. :)
   / M7060 8 speed versus 12 speed #33
… I wish I had the 12 speed because of the parking brake feature, for the increased hydraulic pressure. and it has the creep range which is really nice for hooking up to implements …
Creep range is an option on a 12spd that makes it an 18spd.
   / M7060 8 speed versus 12 speed #35
`keeping in mind that creep gears are not designed for heavy work or excavation...only for slow speed tasks like drilling seed, etc.
   / M7060 8 speed versus 12 speed #36
& us commercial poultry farmers where ground speed well under 1 mph is needed while running a caking machine in poultry houses.
My JD 5115M with creep option has 16spds in creep range all under 1 mph & 32 additional speeds from
.8 mph up to 23mph.
Up North Snow blowers in deep snow requires speeds under 1mph
It’s also a nice feature for a stump grinder attachment.
   / M7060 8 speed versus 12 speed #37
… A 7060 size tractor is a toy to most farms here, yet it's big enough for me.
Did you decide yet which tractor / transmission will fit your application ?
I'm leaning towards the 12 speed 7060, 8 would "do the job" so I want to get some real world local numbers. Taking my time on this one, hoping to do some dealer visits and also check out MF, CIH/NH and Deere for comparison. Kubota easily won that with the current tractor though.
   / M7060 8 speed versus 12 speed #39
Whatever you get, make sure it's a hydraulic shuttle which has no dry clutch at all. Both my M9's are hydraulic shuttle and I've never had to adjust either of them and one is a 2002 and the other is a 2000 and basically all they do is run hay, but then I round bale everything. The cab tractor is an 8x8 with creep gears and the open station is a 8x8 and I've never felt like I need more gears, ever.
I rarely use the creep gears anyway and you have to come to a complete stop to engage them. I can shift up through the main box even though only 1st is synchromesh. I just float the gears and really the only time I do that is when I'm roading anyway.
They are both hydraulic shuttle, and yes, that is a must for me. Zero issues with current 8 speed hydraulic shuttle. I road a lot so the 12 speed appeals there. Creeper is something that I haven't missed really.
Towable Tank (A59228)
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
SUV (A59231)
SUV (A59231)
Blue Diamond 103709 (A53317)
Blue Diamond...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
