m7040
/ m7040 #1
dlay
East tn
kubota m7040/ jd 2155
I put hay forks on and fed cattle for the first time with new m7040, handled two 5x5 rolls, front and rear, well, very stable on hilly ground, beginning to really like the Kubota.
/ m7040 #2
i have one i use it for grading roads and dragging loggs the tractors a little lite for me i have the rear tires loaded and the cast centers and my 3pts a little weak how many hours do you have on yours
/ m7040
I have rear tires loaded also, mine does what I want it to do, so far.
/ m7040 #4
Whats not to like? :)
Here is my M9540.
What county are you in?
/ m7040 #5
I'm curious what are you attempting to pick up with the 3pt that it's weak?? My operators manual states 3300# lift capacity at 24" back.
/ m7040 #7
You may want to find the 3ph lowering speed knob under the seat and see if that helps with better 3ph operation.
Charlie
/ m7040 #8
Glad you like it, we really like our M Series.:thumbsup:
/ m7040 #9
dlay said:
I am in Union Co, where are you located, I used to work all over sw va.
Near Bristol.
/ m7040 #11
the 3pt speed ajustment valve to raise or lower the 3pt faster or slower
/ m7040
Yes they are.
/ m7040 #15
A thought concerning the lift caapacity of the 3 pt hitch. Check to see which hole you lift arms are connected to on the main 3 pt hitch lower arms. There are two positions. One position increases lift capacity and the other how high it will lift. The holes are close together but it makes a significant difference.
Dave M7040
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
Winco 12-Ton Fertilizer Tender Box (A66408)
Winco 12-Ton...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
