M7040 w/ Land Pride 2596 Cutter
   / M7040 w/ Land Pride 2596 Cutter #1
Snakebit12
Raphine VA
Kubota G1800 Kubota BX2360 Kubota M7040
I have a Land Pride RCR2596 that I pull with a Kubota M7040. The cutter literature states that this unit has a cutting height range of 2" - 12".
Currently as is, I have the hydraulic cylinder fully extended (8"). As measured on level ground, the bottom of the deck at full extension is 6" off the ground on all four sides so the deck is level. With the blade about 1" above the bottom of the deck, that means that my max cutting height is 7".
Does anyone have one of these cutters and can explain to me how to raise the cutting height to the advertised 12"?
   / M7040 w/ Land Pride 2596 Cutter #2
tractor3.JPGHere is a photo of my RCR3596 lifted all the way up,never measured it but I bet its gonna be around the 12in. mark.
Here is a close upLP3596.jpg see if you can see anything,that may be different...
View attachment 278239Here is a photo of my RCR3596 lifted all the way up,never measured it but I bet its gonna be around the 12in. mark.
Here is a close upView attachment 278236 see if you can see anything,that may be different...
Unfortunately, everything looks the same. I don't mind mowing pastures at 7" but I'd sure like to raise the deck higher for travel purposes as I have some rocky terrain that I need to navigate.
Thanks for responding.
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
2024 JOHN DEERE 1025R LOT NUMBER 163 (A53084)
2024 JOHN DEERE...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
