Many say that front tire width doesn't make tractor more stable, unless front axle has pivoted to the point it's hitting the stops; and if that has happened you've probably got other troubles (like rear tire has lifted) and it's probably too late.
There's also pros and cons of front and rear tires following same track.
p.s. I never understood how dish in/out puts more strain on the axle. The length of the axle to its connection point on rim is still the same. The weight the axle experiences is still the same, it's seems that just the "lever" (i.e. the offset of the rim's 'dish') is being applied to the axle in the opposite direction. That is, when dish is out, the top of the hub is in compression, the bottom is being pulled away from the axle. When dish is in, the "lever" action torque of this offset is still the same, it's just that the top of the hub is being pulled away and the bottom is in compression. Why is this thinking wrong?
