m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 4,202
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
The heater in the cab is blowing cold air. Checking further into it seems that the actuator that turns the coolant valve to open is not operating. Messicks parts site show it as a 400 dollar item but believe it is for the assembly including the water valve. Will call them on Monday to check on that. See attached pic of the actuator located under the seat. I disconnected the the arm from the actuator and turned it manually as seen in the picture and it works. But taking the seat off to turn it off is needed however it should be good to go for the winter at least.
Would be helpful if someone that has repaired this could share some details of the fix?
