M7040 4wd lever when cold and dash light
   / M7040 4wd lever when cold and dash light #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I warmed up my M7040 for the requisite amount of time. It has been cold here - about -12 degrees C.
I tried unsuccessfully to pull the lever to engage 4WD. The lever just did not move.
After about 20 min of driving I was eventually able to pull the lever with a fair amount of force. Except .... the 4WD dash light does not come on. So I don't know whether it engaged or not.
Just wondering if anyone else has had any trouble with the lever or the dash light.
I was planning to do my 50 hr service myself but I might send it to the dealer so that he can look into this.
   / M7040 4wd lever when cold and dash light #2
Assuming you already know his, but try driving in an S pattern while manipulating lever to/from 2wd/4wd.
Did not know that. If it says this in the manual I will go smack my head against the cab as I try it.
   / M7040 4wd lever when cold and dash light #4
Short S curves, moving the steering wheel left and right while driving and pulling up or pushing down on the lever.
2803 (A50460)
2803 (A50460)
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2010 NEW HOLLAND B95 BACKHOE (A50854)
2010 NEW HOLLAND...
1999 FREIGHTLINER FL80 (A50854)
1999 FREIGHTLINER...
