M7040 4wd lever when cold and dash light
   / M7040 4wd lever when cold and dash light #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I warmed up my M7040 for the requisite amount of time. It has been cold here - about -12 degrees C.
I tried unsuccessfully to pull the lever to engage 4WD. The lever just did not move.
After about 20 min of driving I was eventually able to pull the lever with a fair amount of force. Except .... the 4WD dash light does not come on. So I don't know whether it engaged or not.
Just wondering if anyone else has had any trouble with the lever or the dash light.
I was planning to do my 50 hr service myself but I might send it to the dealer so that he can look into this.
   / M7040 4wd lever when cold and dash light #2
Assuming you already know his, but try driving in an S pattern while manipulating lever to/from 2wd/4wd.
Did not know that. If it says this in the manual I will go smack my head against the cab as I try it.
   / M7040 4wd lever when cold and dash light #4
Short S curves, moving the steering wheel left and right while driving and pulling up or pushing down on the lever.
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
