M6800 vs JD 5205
/ M6800 vs JD 5205 #1
AGV
Hello. I am a new user currently researching my first tractor purchase. I have found this site very informative, containing a wealth of knowledge. I have narrowed it down to a Kubota M6800 versus A JD 5205 (both with FEL). Primary use would be cutting, tilling, light loader work, and eventually some hay production on 100 plus acres. Pros and cons from owners would be greatly appreciated. Thanks in advance...AGV
/ M6800 vs JD 5205 #2
I'm not sure this is a direct comparison between brands. The Kubota is rated at 62 HP at the PTO while the John Deere is at 50 HP at the PTO. Twelve HP at the PTO is pretty significant. That gives the Kubota a 19% HP advantage over the JD 5205. Wouldn't the JD 5325 be a more direct comparison?
Based on the specs, between the M6800 and the 5205, I would go with the M6800. But, saying that, I don't believe it is a fair comparison. The M6800 has more power, has better lift capacities, more reverse gears, and a locking front diff on MFWD models (based on a quick perusal of the websites).
You can probably get better input from others that are more familiar with the dealer line-up of both makes as to which tractors models are more comparable.
/ M6800 vs JD 5205 #3
Yeah, M5700 would be more in line with the 5205.
/ M6800 vs JD 5205
Tjkadar, Thanks fot the reply.
I would agree that the JD 5325 is more comparable to the M6800. Based on local dealer pricing, the 5205 and M6800 are comparable in price. The JD 5325 with FEL is starting to move out of my price range, although I have looked at this model as well. I really like the JD, but would likely be getting more bang for the buck with the M6800... also the M6800 has a fully synchronized main transmission...descions...AGV
/ M6800 vs JD 5205 #6
Did I just talk to you on the phone about an hour ago? Funny thing is I just had a customer asking exactly the same thing for the same situation.
You should know, the M6800 is on its way out and is being replaced by a new M7040. I breezed though the specs and there is virtualy no difference. Pricing is right about the same. There is a major overhaul to the appearance and look and feel. The new tractors look really sharp and the control layout is really nice - much like a big AG tractor with everthing placed on a panel off to the right side. Right now we have 3 on order, but none have a ship date yet. I have heard that other dealers are getting them so it should not be too much longer.
/ M6800 vs JD 5205 #7
If the prices are the same, go for the M6800. You are getting more tractor for your money.
We have a 2005 M6800 MFWD, hydraulic shuttle shift, & FEL on the farm. It is a geat tractor and should do everything you would like. If you have any specific questions on the tractor, let me know. If you can get a 2006 7040 for the same price, I would seriously look at waiting and picking up one of those.
/ M6800 vs JD 5205 #8
I don't know about the new models but that M-6800 is just about the best tractor that Kubota has ever made.
/ M6800 vs JD 5205 #9
I have had the M9000 for a few years now and have been very happy with it. The M6800 is basically the same machine without the turbo and intercooler. It runs very quietly.
Eric
/ M6800 vs JD 5205 #10
The 5205 is a nice machine but the M6800 is alot more tractor.
My choice would be the M6800.
/ M6800 vs JD 5205 #11
Do you mind if I ask what other tractors you had in mind before you narrowed it down to these two?
RedDog
/ M6800 vs JD 5205 #12
Just to be sure, you did get a price quote on the JD 5205 from your local dealer and you are not talking about the list price on the Deere web page, right? I assume you went to the dealer and got a quote, but I thouhgt I'd make sure. Dealer prices are usually (although not always) significantly lower.
Cliff
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
2018 Howden 24 URAI-B Rotary Lobe Blower with Utility Trailer (A61572)
2018 Howden 24...
36 BLADE AC CENTER FOLD DISC HARROW (A63291)
36 BLADE AC CENTER...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
HARDEE TRAILER (A63291)
HARDEE TRAILER...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
