M6800 HDC 4WD
/ M6800 HDC 4WD #1
fcoats
Grenada, MS
Kubota 6800
I aqm having a hard time shifting out of 4WD. It easiloy shifts into 4WD stopped or moving, but I have to be moving with pressure on the shift mechanism for it to **** out of 4WD. Any ideas and how to fix it so it shifts easily?
Thanks
/ M6800 HDC 4WD #3
I'll second what number two stated. Because of improper inflation and/or tire wear the match of gearing gets off. I did own an older 4WD that I couldn't get out of 4WD if I didn't change directions especially if I ever entered a blacktop road.
/ M6800 HDC 4WD #4
Ditto the above posts. It is just normal 'axle fight'. A brief change in direction should make shifting easier.
/ M6800 HDC 4WD #5
There was a post about this some time ago and if you just turn to the left it will come right out everytime.
Sterling AT (A63689)
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
Attention (A57148)
Attention (A57148)
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
