m6800 cab with no reverse
   / m6800 cab with no reverse #1
jonsstihl
Quebec, Canada
My father in law has an m6800 cab with the four speed transmission with hi lo and creep range so I guess thats 12 speed with the shuttle shift on the column for forward neutral and reverse. the tractor is a 2000 model year. with about 1800 hours
he has been having trouble lately with the shift linkages. he lost 3 and 4th gear a couple weeks ago so he took it to the dealer and they adjusted the linkage, and it worked fine after. Now he lost reverse on the shuttle shift.
just trying to help him out if anyone has any ideas if it is something simple
thanks
   / m6800 cab with no reverse #2
If this M6800 has the hydraulic shuttle I'd look for a linkage problem somewhere between the steering column lever and the valve (under the floorboard) - or maybe low oil level. Is the 3-pt hitch working ok? If the shuttle is mechanical see next post.
   / m6800 cab with no reverse #3
If it is a mechanical shuttle, the shifter moves a collar in the front compartment to engage a different gear set to change directions.
Be sure the linkage moves all the way to the top of the transmission or it could be internal
Good luck
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250 XL...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
