m6800 cab with no reverse
   / m6800 cab with no reverse #1
jonsstihl
Veteran Member
Quebec, Canada
My father in law has an m6800 cab with the four speed transmission with hi lo and creep range so I guess thats 12 speed with the shuttle shift on the column for forward neutral and reverse. the tractor is a 2000 model year. with about 1800 hours
he has been having trouble lately with the shift linkages. he lost 3 and 4th gear a couple weeks ago so he took it to the dealer and they adjusted the linkage, and it worked fine after. Now he lost reverse on the shuttle shift.
just trying to help him out if anyone has any ideas if it is something simple
thanks
   / m6800 cab with no reverse #2
If this M6800 has the hydraulic shuttle I'd look for a linkage problem somewhere between the steering column lever and the valve (under the floorboard) - or maybe low oil level. Is the 3-pt hitch working ok? If the shuttle is mechanical see next post.
   / m6800 cab with no reverse #3
If it is a mechanical shuttle, the shifter moves a collar in the front compartment to engage a different gear set to change directions.
Be sure the linkage moves all the way to the top of the transmission or it could be internal
Good luck
2016 ROADTEC RP-190E ASPHALT PAVER (A51222)
2016 ROADTEC...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
Quick Kurb Continuous Curbing System with MEGA MARKER (A49461)
Quick Kurb...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
