M6800 3 py hitch need help
   / M6800 3 py hitch need help #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I have a M6800 tractor that I am having some 3 pt hitch issues.Right now I have a 3 bottom plow hooked up but cannot use them since the last bottom is on the ground .Seems like The lift arms do not goe high enough.I have tried shortening up the top link but it does not really help much.The arms have to beable go higher than they do.Even a backblade does not go up very high.Any thoughts --Thanks. Ed
   / M6800 3 py hitch need help #2
I think there is a lever to be switched to limmit the lifthight .....mybe its switched to limmit the lifthight ?
   / M6800 3 py hitch need help #3
With no implement on 3 pt and control lever at rear of quadrant lift up on 3 pt draft arm. If arm moves up then feedback rod can be "CAREFULLY" adjusted for maximum raise height. With 3 bottom plow attached to 3 pt hitch center link should be attached in lowest hole on tractor center link bracket. This will give maximum lift and maximum draft sensitivity.
Where is this feedback rod located.I am on lowest top link setting.What do you mean by carefully ? Go slow or keep adjusting slowly ? Thanks
   / M6800 3 py hitch need help #5
1st check by lifting on 3 pt draft arm to determine if 3 pt rockshaft isn't rotating up to it's limit. Feedback rod is attached to LH arm that's splined on rockshaft and it has a turnbuckle with a locking nut on each end. If turnbuckle is adjusted to far it will cause RS relief valve to go in bypass which could cause RS housing to CRACK!!!!!!!
Turn a revolution at a time ?Is that safe to assume andthen see ifthe arms lift more ?
   / M6800 3 py hitch need help #7
Yes that's correct with control lever at the rear of slot with engine running. Listen for relief valve to open & if it does reverse turnbuckle nut until relief valve reseats.
"control lever at the rear of the slot"---are you referring to the 3 pt lift handle all the way up ? I think I found the feedback arm--about 5-6" long .
   / M6800 3 py hitch need help #9
"control lever at the rear of the slot"---are you referring to the 3 pt lift handle all the way up ?.
YES I was referring to the 3 pt control lever
Will try it this weelend and cross my fingers.Is there a section in the service manual that refers to this adjustment ?
2023 CFG QNT45 Mini Excavator (A49461)
2023 CFG QNT45...
IH 1566 Tractor (A50514)
IH 1566 Tractor...
John Deere 4020 Tractor (A50514)
John Deere 4020...
1240 (A50490)
1240 (A50490)
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
