M62 Fit RiteTop'nTilt/Rear Remotes
   / M62 Fit RiteTop'nTilt/Rear Remotes #11
He'd have to remove the power beyond from the 3 stack valve he got from Fit Rite. Probably should contact Fit Rite for instructions.
   / M62 Fit RiteTop'nTilt/Rear Remotes #12
Example of power beyond plug in a Prince valve. Some valves are different and have an adapter with o-rings to seal the high pressure from the tank circuit.
   / M62 Fit RiteTop'nTilt/Rear Remotes #13
I see. That's clever - with the backhoe mounted there is probably no use for the remotes, and with the BH dismounted there is no use for the swing pump.... but when the hoe is dismounted there are these handy swing circuit connections which are lonely and unused.
But is there any advantage other than using two shorter hoses? - I'm assuming that on the M59/62 the hoses to the swing pump outlets would be closer than those to the power beyond port on the control valve.
   / M62 Fit RiteTop'nTilt/Rear Remotes #14
This person used the swing cylinder circuit for his rear remotes on his L47. He made the connection and valve body removable. Looks like a good way to go.
Doug
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
