M62 FEL Bucket Cylinders
   / M62 FEL Bucket Cylinders #11
When I read M62 loader, I thought it would be the Canadian version. In Canada, Kubota puts Alo made loaders on. I think from M6060 on upwards and calls them M.
   / M62 FEL Bucket Cylinders #12
If you disconnect the lines and cap them, the air that you get in will allow some initial sag. But then it takes time anyways to figure which part(s) are letting oil through.
   / M62 FEL Bucket Cylinders #13
Holy cow ! Is this a third party loader not a Kubota and not installed by your dealer? I did not know anyone even made a loader not designed to be removable (even if not a quick removal type.) Even so I cannot imagine putting on a loader without disconnects. Maybe it is worth having a set of quick disconnects put into the 4 lines for the loader near the loader valve and while that is being done they can debug your original issue.
On Kubota TLB models the loaders are standard equipment not an option.
The curl cylinders are accessible allowing some easy troubleshooting to determine a cylinder or valve problem.
Had a Canadian built loader on a M5030DT. Heavier and stronger than the US version. Canadian backhoe on a US M59.
  • Good Post
Reactions: JWR
CFG Industrial MX15RX (A56469)
CFG Industrial...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
2014 Freightliner M2 106 Ambulance (A55852)
2014 Freightliner...
2014 Evans 48' Drop Deck Trailer (A56469)
2014 Evans 48'...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
