M6040 Disc size?
   / M6040 Disc size? #1
drollz
I have just purchased a m6040 w/fel 1153, fluid in my tires, 300 lbs of weight on each rear tire, and 72" box scraper with scarifiers. It will be delivered today. I was wondering what size disc would be just right for this size of tractor. I have 20 acres of mostly sandy loam. Also should I look for a pull behind or a 3-point type? Which will be better?
drollz
central valley ca.
   / M6040 Disc size? #2
I have a 5040 w/loader so we are pretty comparable. Personally I prefer a pull type disc because it typically penetrates the soil better but if you are using it in tight working areas then you will probably be better off with a 3pt hitch because it is much more manueverable. 3pt hitch discs typically don't weight as much so they generally don't dig as deep but a couple of extra passes usually makes it comparable to the pull type(at least on the soil that I am in). As far as size I am using both 8' discs(pull and 3pt) and my tractor handles it fairly easily. I would definitely get something a little wider than your tractor that way you can go along the edge of a treeline and not have to put the operator so much into the trees/brush of the field edge. At least that is my thoughts.
INSPECTION (A51573)
INSPECTION (A51573)
Road Drag (A50514)
Road Drag (A50514)
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
2004 John Deere 6220 (A52128)
2004 John Deere...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
