M5950 transmission growl
/ M5950 transmission growl #1
Jervis
New Glasgow, NS
2012 Massey Ferguson 1648 Dyna, 2008 Kioti CK20s HST, 2012 Kubota B2630 w BH77
I have recently purchased a 1990 m5950dt. I have concern/question about the tractor in regards to a growling noise when the transmission is in neutral with the clutch engaged. The noise sounds similar to a bad throw out bearing but the clutch is engaged so the throw out bearing shouldn稚 be turning.
When you depress the clutch pedal to disengage the clutch the noise goes away. Does it sound like a problem with an input shaft bearing or something like that or is it a common clutch chatter noise with these tractors.
Any advice is appreciated
/ M5950 transmission growl #2
The throw out bearing will spin exactly when you push the clutch, so yes, it might be your problem.
When your foot is off the clutch, the bearing shouldn't even be touching the clutch.
This noise is with your foot off the clutch pedal, once you depress the clutch it goes away
/ M5950 transmission growl #4
My l3800 makes the same noise, Then you push in the clutch it goes away been that way for a long time .....
Thanks for the replies
The pilot bearing would normally be turning with the input shaft when the clutch is engaged would it not? I would think that you would be more inclined to hear it when the clutch is disengaged and the clutch is spinning around the stationary input shaft.
Does that sound correct?
/ M5950 transmission growl #8
Yes, that sounds correct to me on the pilot bearing. I believe a bad pilot bearing/bushing would make a sound oppositely to what you are hearing. I've been thinking about the grumble and trying to come up with anything that it could be EXCEPT a bearing somewhere along in the transmission along the input shaft..... and not coming up with much.
Check me on my understanding - the noise exists when the clutch is engaged and the transmission is in neutral so that the input shaft is turning. The noise is a low grumbling sound, and it goes away or changes when you step on the pedal to disengage the clutch. Is that correct?
And I'm guessing that the noise actually decreases when you put it in gear and drive off. Is that so? 2wd vs 4wd?
I am assuming that you have enough free play in the clutch system so that the throw-out bearing isn't touching the pressure plate when the clutch is engaged. That's worth checking. As a test, you could pull backwards on the lever that works the throw out bearing just to make sure it has clearance from the pressure plate.
Another check is to look at the oil or cut open the hydraulic oil filter. You may see particles or silvery metal flakes if it is a bearing.
It may also be possible to take off the shifter cover and peer around inside. Not sure if you can on that transmission, but if you can it is easy and always a chance of learning something. Do not run it with the cover off. The shift collars not only shift the gears, they keep the gears from moving freely and shifting themselves.
Once or twice in my mechanical career I've been lead astray by thinking I had a bad bearing when what was actually happening was that a piece of metal had gotten bent or somehow leaning on the engine/transmission case and was vibrating so that it sounded like a bearing. Rare, but it has happened to me so worth a look.
If those tests don't help, then infortunately it does sound like a transmission bearing. It may not be the tranny input bearing; it could be a bearing anywhere along that input shaft. Some transmissions are made in two pieces that slide together with a bearing isolating the front and rear halves. I am not sure what the Kubota tranny looks like, but all manual transmissions are similar.
best of luck,
I think that's a great tractor with a great transmission. Sorry for the problems, but worth fixing.
rScotty
it does sound like that's where it is coming from.
/ M5950 transmission growl #9
With traction clutch engaged pilot brg would not be an issue. I think growling noise is a faulty trans input shaft brg.
Thanks for the replies fellas, it is much appreciated. I will check the clutch free play but don't think that is the issue. The noise goes away as soon as the clutch pedal is depressed a little. It is hard to tell if the noise goes away when you start moving as other noises get louder but it is hard to hear it at anything besides sitting in neutral. It does not matter if it痴 in 4wd or 2wd.
I plan to complete a full fluid change out in the next couple weeks I will check the filter and oil for any metal particles.
Thanks again
/ M5950 transmission growl #11
Thanks for the replies fellas, it痴 much appreciated. I will check the clutch free play but don稚 think that痴 the issue. The noise goes away as soon as the clutch pedal is depressed a little. It痴 hard to tell if the noise goes away when you start moving as other noises get louder but it is hard to hear it at anything besides sitting in neutral. It doesn稚 not matter if it痴 in 4wd or 2wd.
Thanks again
Same as my tractor if you push the clutch down just a little bit the noise stops ...:confused3:
I have run into issues in the past with the dual disk clutch on my dodge diesel where there is a rattle from the clutch in neutral at idle from the friction disk hub springs. Once you come off idle the centrifugal force keeps springs from rattling. Wasn稚 sure if the clutch setup in this tractor was similar and thus the noise would be considered fairly benign.
Or I have a bearing issue as others have mentioned
Sorry for the late update I just got around to changing the hydraulic oil. I changed the filter and hydraulic oil and inspected the magnet as well as cut open the filter.
The magnetic had hardly anything on it and I found a few very small specks of shinny metal material in the filter but not what I would consider alarming. Given there wasn’t much found on that inspection I will likely operate it for a while and if it gets louder/worse I’ll have to do some repairs then.
Thanks again
/ M5950 transmission growl #15
1984 m5950DT same issue. I think mine is getting louder which prompted me to visit this thread again. Anyone have more info?
Sorry for the late reply guys. I ended up selling the tractor. Not for that reason but I had an opportunity to buy a nice low hour massey 1648.
The guy I sold it to is still operating it and has not reported any issues. Sorry I couldn’t be of more help.
