M59 to the rescue!
/ M59 to the rescue! #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
We've just had the mother of all floods here in Jamestown, Colorado, and I've got a ton of info on how an M59 works when doing real difficult work in gravel to boulders. I'll post some pictures, but right now internet access is still very limited.
But I'm a long time contributor, looking at a massive cleanup, and need to ask a specific question tonight.
What is the of the pressure washers?
What features should I be looking for? Does Kubota make one?
I don't mind spending money on good tools, and this one will get a workout.
Thanks, rScotty
/ M59 to the rescue! #3
Gallons per min at what pressure....
You want the highest Gallons at the highest pressure you can afford.
You can Always reduce the pressure by going to the next larger number set of tips... But you can not increase pressure without damaging something by going to a smaller number tip set.
So look for the pump system with the highest gallonage flow, and you can use tip set number to get the pressure you want.
/ M59 to the rescue! #4
What KennyV said.
That said, you might consider a fire pump for where you live rscotty. They make a pretty decent pressure washer and might be better for your cleanup.
Good to see you are putting it all back together.
