M59 relief valve questions.
   / M59 relief valve questions. #1
Hersheyfarm
NE ky
I know there is two under the seat but the backhoe has three on the control valve. They are adjustable. If they are set at a very low pressure setting would that not be harmful. Making the hoe weak but producing excessive heat. Now, to set them would I plumb in a gauge for each circuit and set pressure by bottoming out the cylinder for that circuit? Wouldn't the main relief valves kick in?
I seem to have posted this in the wrong forum.
   / M59 relief valve questions. #3
I wouldn't touch them, if in warranty, let them diddle with it.
   / M59 relief valve questions. #4
I have the procedures for adjusting the relief valves. Send me a PM and where I can send you some information.
D&B
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A53843)
2021 ALLMAND BROS...
TRANSMISSION JACK (A53843)
TRANSMISSION JACK...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
